Noisy rear door
L
Lakes_Puma
Wiltshire, UK
Since picking up my Ocean I've noticed a very annoying noise from the rear passenger side when driving, like a metal and glass sound, not a plastic squeak, and I think I've narrowed it down to coming from the the passenger side rear sliding door.
When I open the door and compare it to the other door, there is up and down movement of the top runner on the noisy door whereas the drivers side door is rock solid.
Has anyone had a similar issue and or known the resolution, obviously if it's something major it will be going into the dealers for repair?
I had a very similar noise and was convinced there was something wrong with the passenger side sliding door. I went for a test drive with a technician and he worked out it was a rattling (plastic) fuel pipe which had not been clipped in properly. Probably not your cause but I thought it worth mentioning.
