Can you recall exactly how the roller applied the tape?Saw tape being applied with roller tool by hand in Hannover factory Easter 2017 .
Looking around my roof the visibility of my tape is very varied. Sometimes outside and sometimes inside. I have yet to find a point where it is visible in and outside at the same point. This suggests that it is applied by hand and eye. Not best process for high, repeatable and consistent quality.Can you recall exactly how the roller applied the tape?
I noticed something else too. I can not spot any tape anywhere except at the back of the Cali. It might be me not being thorough enough but I have a suspicion.......
In my mind and irrespective of what VW do its got to be better to have a wider tape so that it protects against corrosion inside and outside of the pop-up roof. So, yes, 25mm has to be better. It provides better security and so for the relatively small extra cost (?) over the 15mm version I would chose this every time.Thanks for that, very interesting. I would like to know if the 15 mm wide tape now listed as a roof part is the same as is applied at the factory. The only way to find out is for someone to pull off a small section of roof seal and measure it. My van is being done now, I a leaning toward 25 mm wide 3M tape rather than the VW option of 15 mm.
My suspicion is not eating at me and as I am one of the "don't look" until nearly 3 years has passed I will not confirm or otherwise that suspicion.Pull a small section of rear roof seal down and have a look, it is not difficult.
Seems to be and it's likely they will replace the canvas.
Roof repair procedurePhoned again today, it seems they are re fitting my own canvas, do you think VW really have a procedure to cover this paint repair process? On the up side no re doing midge protection measures.
I had the elevating roof of my 2015 T5 repaired in August by Marshalls of Newbury. The bellows were in excellent condition and they said that they would not be changing them. Nevertheless, when I collected it from Breeze seventeen days later, the bellows had been changed for the new T6 type. When I queried it with VWCV they said that the bellows had been damaged during the repair and they had to be replaced under warranty.Roof repair procedure
When the original repair procedure was set up to be done by the original five selected repair shops, they was supplied with all the necessary parts, I believe this was down to every single washer so is that a complete new roof, including including “NEW BELLOWS” This is in fact what happened to SusiBusT5, which was one of the first ones to be repaired. I inquired why it was necessary to change the bellows and was told that because it was a very difficult job to remove the bellows without damaging them, and it has been decided to supply a complete kit for every vehicle to avoid hold ups.
Whether in the subsequent years the procedure has been modified to save money I don't know.
What I do know is if I had a choice, I try and make sure I had T6 type bellows were fitted, which I think are much superior to the T5 ones. I do believe some people have had these fitted.
I do seem to require recall that in the past someone posted that if only the elevated section of the roof required repair, they would trying to do this without removing it and separating the bellows from the aluminium section. Quite how they would have achieved a satisfactory job without removing the bellows is beyond me!
More importantly there was still evidence under the seal of bubbling paint. Even worse was the fact that there was also corrosion to the front roof section, a problem that was apparently fixed by VW in 2014, that they had totally missed. It has been booked back in for 13 November. I wonder if it will have the bellows replaced yet again? What a waste of time and money!
I was amazed, but so were VWCV. They said this was the first reported problem since the “fix”. From my point of view it’s really disappointing because it’s a much more invasive repair than the bubbling under the rubber seal. There is more detail in my posts under T5 Only.What a shambles, gives me no confidence in VW repair at all. It is worrying that you have found corrosion on the front roof section on a 2015 van, ours is 2014 no sign of any issues so far. Can you please post a photo of the front corrosion. If they have not sorted this problem the T6 vans could also be affected.
I will be giving my van a thorough inspection when I get it back, I intend to fit the tape VW now apply after the repair and fill the seal with silicon grease. I really do think if I can avoid the need for a further repair it will be worthwhile.
Pictures taken this morning of the front roof panel corrosion on my May 2015 T5. I know that this thread is for T6 only but this may be of interest because the problem clearly was not "fixed" in 2014.I was amazed, but so were VWCV. They said this was the first reported problem since the “fix”. From my point of view it’s really disappointing because it’s a much more invasive repair than the bubbling under the rubber seal. There is more detail in my posts under T5 Only.
I’ll try to post a picture as soon as it stops raining!
View attachment 26771 View attachment 26772
